Pegasystems
Last activity: 5 Aug 2016 6:37 EDT
The reference <code block> is not valid. Reason: FUAInstance-NullMyStepPage
Hi i could not understand what does it mean
"The reference <code block> is not valid. Reason: FUAInstance-NullMyStepPage"
It occurs when i click on a option from dropdown.
Please help me out .
Pegasystems
not only solution and I want to learn debugging please add either solution or debugging steps i will try to figure it out.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689961000/15921432-279a-442f-a2df-7ab5949bdee8.jpg?itok=-ctthCbD)
I have seen this occur in Chrome specifically. Can you indicate ther browser you are using?
Pegasystems
i m using IE 8
Coforge Limited
Hi, is there any solution for this?
Incessanttechnologies
i am getting same issue. when i am doing obj-Save.
Error:
The reference .pxResultCount>0 is not valid. Reason: FUAInstance-NullMyStepPage
Can any one help me .Thanks in Advance.
Coforge Limited
Hi Swetha,
We got a hotfix for this issue from Pega Systems.
Would recommend you to do the same by sharing the trace logs and system logs with them for analysis.
HFix-10226 is the hotfix we got, maybe you can share this also with PS. We use Pega 6.2 SP1
Thanks, Dheena |
Pegasystems
The property reference is unable to find in current context page so if this occurs while trying to call another activity we need to pass correct context page to that. some times we need to specify correct step page in the activity if it is not present.
I-Teco
RU
We have the same error on Pega 7.1.7, browser Firefox.
Souvik Mitra Vladimir Stanislavski
