Accenture
Last activity: 6 Nov 2015 8:28 EST
Where can i find list of JavaScript API?
Like we have "Public API" for all the Java related work, where we can find all the function that we can use in PEGA in JSP /JAVA.
Where can i find the list of javascript api that pega uses?
You can navigate to the Help Menu - > beside the operator menu.
There we have the PegaDeveloper Javascript API sub menu, which has links to documentation of several API classes that may be of interest to you.
infosys
Hi BOKKS
The image is not clear. Can you please repost.
Accenture
Is there anything like this https://community.pega.com/sites/default/files/help_v63sp1/Content/javadocs/index.html for java lib] for javascript as well?
Tech Mahindra
Hi BOKKS
i can't find the Desktop API(UI API) which one was available in 6.* of pega versions. Can you guide me where can i see in V7.1.7
Tech Mahindra
they have disabled it by default, you can private check out it.
Accenture
Thanks KalyanYapuram, Is something similar is available in 6.2 SP as well
Accenture
Cloud Pega 7 does not have the javascript api by default.
Do we need to add it ? and How do we add it?
Accenture
Is it possible to find the documentaion of OpenSpace javascript method, like what all parameter can we pass into this?
