Last activity: 29 Jun 2022 8:57 EDT
Web Components SDK update – SDK-WC.87.1 now available!
A new release of the Web Components SDK is now available – SDK-WC.87.1
Marketplace download: https://community.pega.com/marketplace/components/web-components-sdk
Github code repository: https://github.com/pegasystems/web-components-sdk
Updates include:
- Added support for Infinity 8.7.2
- Added use of npm dependency to get necessary ConstellationJS Engine files (see package.json @pega/constellationjs dependency). You no longer have to get and unzip the files from the Marketplace download!
- Added playwright smoke tests that can be run against the MediaCo sample app
- Improvements to auth code and to make it easier to deploy the SDK on a different web server (ex: Tomcat)
- The Web Components SDK does not include every component that a Constellation application supports. At this time, we provide the most commonly used components to get you started with your application.
Background:
The Web Components SDK includes a bridge and DX components that connect the Constellation JavaScript Engine to a Web Components-based design system. The SDK provides a front-end developer friendly NodeJS environment for building an application’s UI using a different design system than Cosmos React. The alternative design system used in the Web Components SDK is based on Lion and LitElement.
