Ford motors India
Last activity: 15 Jun 2020 6:51 EDT
Validating branch merge submitter
As part of pre-merge validations, we need to validate the branch submitter to make sure of below ones:
- Submitter has all the required privileges.
- Submitter is not a test operator or some generic operator.
Pega provides an extension point in the pre-merge process to accommodate above validations. Below are the steps to hook our custom validations in the merge process:
- Save a copy of the standard “pyValidateMergeOptions” to a RuleSet available to your application.
- Add the steps you want the system to perform to that copy.
Below example would explain a simple scenario where we maintain a list of operator ID’s and verify if the branch submitter operator ID is in the list before each merge.
Steps:
- Save a copy of “pyValidateMergeOptions” to a RuleSet available to your application.
- Create a Decision table to store a list of operators as below:
3. Validate the operator ID in the saved copy of “pyValidateMergeOptions” and set a error message on primary page.
This would stop the merge in the wizard showing the error message if the user is not authorized.
This is a frequently asked question about Deployment Manager. Find more answers here.
