Using React with Pega
A Case Worker portal built entirely with a React framework, using the Pega Digital Experience APIs
How you can stay in React to change styles, controls, and layouts. You’ll also see how UI elements changed using Pega’s no-code designer immediately become reflected in React without additional coding.
React (Styles, Controls and Layouts)
Installation Instructions
1. Install Yarn. Installation link [here](https://yarnpkg.com/lang/en/docs/install/#mac-stable). 2. Using a terminal, cd into PegaApp directory (the directory this file is in). 3. Run the following commands: * `yarn install` * `yarn start` 4. This should open your browser to http://localhost:3000, which is where the application will be served.
Then tried to modify the endpoints.js file to point the application to your server.
For example, https://{your system URL}/prweb/api/{v1}
Here, v1 is the name of the api. Search in your pega application with corresponding api name and you will get the full web address of desired system.
Pega React component
https://collaborate.pega.com/question/pega-react-component https://collaborate.pega.com/question/how-use-react-pega#comment-819526
Where we can React Components for Designer Studio
Designer Studio -> User Interface -> Gallery -> UI Elements -> React components (under Extending your Pega UI section)
***Edited by Moderator Marissa to update Content Type from Idea to Discussion***
