There was a problem getting a list: code: -206 SQLState: 42703 Message: PXCOVERINSKEY IS NOT VALID IN THE CONTEXT WHERE IT IS USE
HI All,
I am facing an issue while creating a child case from a parent case. I am getting the following error.
There was a problem getting a list: code: -206 SQLState: 42703 Message: PXCOVERINSKEY IS NOT VALID IN THE CONTEXT WHERE IT IS USED. SQLCODE=-206, SQLSTATE=42703, DRIVER=4.22.37 |
| Detailed exception:
[MSG][Error retrieving top level cover key for: abcd-WORK 20205255 in abcd-Work-Request][STACK][com.pega.pegarules.pub.database.DatabaseException: There was a problem getting a list: code: -206 SQLState: 42703 Message: PXCOVERINSKEY IS NOT VALID IN THE CONTEXT WHERE IT IS USED. SQLCODE=-206, SQLSTATE=42703, DRIVER=4.22.37 DatabaseException caused by prior exception: com.ibm.websphere.ce.cm.StaleConnectionException: PXCOVERINSKEY IS NOT VALID IN THE CONTEXT WHERE IT IS USED. SQLCODE=-206, SQLSTATE=42703, DRIVER=4.22.37 | SQL Code: -206 | SQL State: 42703 DatabaseException caused by prior exception: com.ibm.db2.jcc.am.SqlSyntaxErrorException: PXCOVERINSKEY IS NOT VALID IN THE CONTEXT WHERE IT IS USED. SQLCODE=-206, SQLSTATE=42703, DRIVER=4.22.37 | SQL Code: -206 | SQL State: 42703 DatabaseException caused by prior exception: com.ibm.db2.jcc.am.SqlException: THE DESCRIBE STATEMENT DOES NOT SPECIFY A PREPARED STATEMENT. SQLCODE=-516, SQLSTATE=26501, DRIVER=4.22.37 | SQL Code: -516 | SQL State: 26501 DatabaseException caused by prior exception: com.ibm.db2.jcc.am.SqlException: THE CURSOR SQL_CURLH200C5 IS NOT IN A PREPARED STATE. SQLCODE=-514, SQLSTATE=26501, DRIVER=4.22.37 | SQL Code: -514 | SQL State: 26501 From: (H49C1484EEAC90F0A83FCF535E63FAC6B: Proprietary information hidden) SQL: select pxCoverInsKey as "pxCoverInsKey", pxObjClass as "pxObjClass" from DTPEGASD.project_WORK where pzInsKey = ? Caused by SQL Problems. Problem #1, SQLState 42703, Error code -206: com.ibm.websphere.ce.cm.StaleConnectionException: PXCOVERINSKEY IS NOT VALID IN THE CONTEXT WHERE IT IS USED. SQLCODE=-206, SQLSTATE=42703, DRIVER=4.22.37 Problem #2, SQLState 42703, Error code -206: com.ibm.db2.jcc.am.SqlSyntaxErrorException: PXCOVERINSKEY IS NOT VALID IN THE CONTEXT WHERE IT IS USED. SQLCODE=-206, SQLSTATE=42703, DRIVER=4.22.37 Problem #3, SQLState 26501, Error code -516: com.ibm.db2.jcc.am.SqlException: THE DESCRIBE STATEMENT DOES NOT SPECIFY A PREPARED STATEMENT. SQLCODE=-516, SQLSTATE=26501, DRIVER=4.22.37 Problem #4, SQLState 26501, Error code -514: com.ibm.db2.jcc.am.SqlException: THE CURSOR SQL_CURLH200C5 IS NOT IN A PREPARED STATE. SQLCODE=-514, SQLSTATE=26501, DRIVER=4.22.37 at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:262) at |
Getting this error from activity pzLoadCaseHierarchyWrapper step 5 Java
ParameterPage newParamsPage = new ParameterPage();
newParamsPage.putString("AlwaysBuildTheTree",tools.getParamValue("AlwaysBuildTheTree"));
try{
// Build for existing work objects
pega_processengine_workutilities.pzMapCases(tools.findPage("pyTopCaseMap"), myStepPage, newParamsPage);
catch(Throwable t){
throw new com.pega.pegarules.pub.PRRuntimeException("exception with pzmapcases", t);
try{
// Add current work object
pega_processengine_workutilities.pzAddCaseToMap(tools.findPage("pyTopCaseMap"), myStepPage);
catch(Throwable t){
throw new com.pega.pegarules.pub.PRRuntimeException("pzaddmapcasetomap", t);
