Last activity: 26 Aug 2020 13:21 EDT
This content references Pega Express in regards to App Studio. The Pega Express product was renamed “App Studio” starting in v8.
Is there an easy way to switch between the Pega Express and Developer Portal?
I'm currently running 7.2 and after creating a new application using Pega Express, I would like to switch to Designer Studio portal. I can modify the access group and set developer as the primary portal. But can't see an option from Pega Express to change portals. Is that possible?
Thanking you in advance,
Andrew
I will contact Pega Engineering myself directly.
Andrew
In the trial cloud, we do not provide access to the Developer portal.
On-premises, there is an icon in the bottom left of the screen that is visible when Editing mode is turned on that allows you to switch to the Designer Studio.
Citizens Bank
Dennis,
Do you know if the newest Personal Edition has this functionality built into it? (The ability to switch between environments) I'm asking because I requested a copy of the Personal Edition about a week ago and still haven't heard back so I haven't been able to try it myself yet.
Jay
Updated: 28 Mar 2016 12:50 EDT
The capability so switch back and forth should be available in Personal Edition for 7.1.9+. It requires that both the Developer and pxExpress portals are listed on the appropriate access group.
Mphasis
I am not able to see "turn on editing" button in Pega express portal if i login as an enduser to pegaexpress portal in Pega 7.2.
where as i can able to switch from designer studio to pega express and here i can see turn on editing button in right below to the screen.
Do we need to add any role to get "turn on editing" button in Pega express portal ?
The Express Studio portal (the one that supports editing) is called pxExpress. Users with Designer Studio access are always allowed to switch to Express. If you want a user to log directly into Express Studio and have the ability to edit the app. The access group must be configured to log into pxExpress with an end user portal as a secondary portal. pyPega7Express is a simple end user portal that is similar to the case worker portal.
By default, we generate an Author@[your org] access group for new apps and orgs that are configured this way.
Comptech Associates
What is the main difference between pega desiner studio and pega express
Pega Express:
Pega Express exposing key elements and features in an accelerated environment. Pega Express showcases stage-based case management, the ability to edit your designs as you build and run your application, and tools to preview your user interface on a desktop, laptop, tablet, or mobile phone. By using Pega Express, you build applications quickly and without classroom training. You can start using any of the interactive tools and features at your own pace. For a more guided approach, you can take a tour or complete the tasks that are displayed in the Achievements widget of your dashboard. Context-sensitive help and online help are also available to assist you each step of the way.
There are few design time limitation which can be overcome by using Pega Designer Studio. Refer https://community.pega.com/sites/default/files/help_v731/express/procom…
Pega Express:
Pega Designer Studio: Designer Studio is a web-based integrated development environment that you use to build applications. Designer Studio provides access to tools, wizards, reports, and other features.
