Source dropdown from decision table
I need to source a dropdown based on some parameters.How to do this with decision table?
There may be an easier way to dynamically source your drop down list by using a Data Page (ideal) in combination with a Report Definition and or a Data Table. What is your usage scenario?
Henry
Pega Academy
Hi Praveen, you can achieve your requirement as follows...
Data Page
--> Source: Data Transform (say: LoadInterfaceConstants)
In Data Transform, load results from Decision Tree as
Param.returnValue = @(Pega-RULES:DecisionTable).ObtainValue(tools, Primary, "MapInterfaceConstants", false)
where MapInterfaceConstants is your Decision Table
In your Decision Table, configure the Result Actions as .Interface(<append>) [Where Interface is the pagelist].
Hope this helps !!!
