Cognizant Technologies
Last activity: 20 Apr 2016 13:13 EDT
Setting Page Context to Use Data Page
I have created a Data page called "D_Position" and trying to set this as a page context in Postion page property. I have set up the page context as "Use data page" , but the D_Position is not displaying it. Even if I manually typed it, I am unable to select "Reqid". Please help me to fix this issue.
Venkadesh K
Likes (7)
Arnab Banerjee Arun Puram MOHAN PAWAR mounika kalvakuri Arun Kothapalli and 2 More -
Venkadesh,
I have a doubt. Can you post a small screen shot of the "Edit Property" form you are working with?
Here is an example of that page. I do not understand how you "set up the page context as use data page" unless you are referrring to the Data Acess option.
eddie
I am unable to paste the screen shot here. But the problem is I am working on the exercise "Creating Dynamic User Interface" from "SAEI_71ML_6_ExerciseGuide_20141218". This is from system essentials I.
Venkadesh K
OK, I think I understand where you are at now. In the Data Page Parameters section, you should be using .PositionAppliedFor as the value.
Are you using the online exercise environment?
if you are, would you be willing to post the URL here so I can have a look?
eddie
Yes. You are correct Eddie. I am using .PositionAppliedFor as the value. Here is the problem is.
Usuallay if you put a dot(.) it will display all the properties you can choose one of them, but here nothing is happening.
Please find the URL below.
From this URL I am trying to update the properties of SelectNewPosition_Position.
Venkadesh K
Anybody help me for my above question?
Venkadesh K
COGNIZANT TECHNOLOGY SOLUTIONS
Venkadesh
Above Url is not working...can u plz send it once again?
Venkadesh K
Venkadesh K,
This URL is from the local virtual machine - what we call the PVS - that you downloaded. I will not be able to access it.
What exercise are you working on? Is it the "Populate Dropdown From a Data Page"?
eddie
I am working on the exercise "Creating Dynamic User Interface" .
Venkadesh K
OK - let me look at that one and I will get back to you.
eddie
Can anybody help with this issue? I am still facing the same issue.
Venkadesh K
Venkadesh,
if I understand this correctly, you are on step 9 (pg 112).
all you should have to do is use .PositionAppliedFor as the value in the field for ReqID.
eddie
I am in Page number 113 trying to set the page context as "Use Date Page".
OK, if I am tracking this correctly, you should be using .PositionAppliedFor in the ReqID* field. And, that is not a prompt list type field, so you will not see any sort of list from which to choose a property.
Hi Eddie,
I am unable to choose D_Position as my Page Context. After I choose the page context as Use data page, I am unable to select D_Position.
That exercise may not be as clear as it needs to be. Simply type the data page name into the field - it will work.
eddie
Updated: 20 Apr 2016 13:13 EDT
Express-Scripts
xcxcxc
