Send check
Hi!
Activiti Notify sends email.
How to check sent email or not?
Thanks in advance for your answer.
Hi!
In Pega 7, when the notification email is sent it is typically noted in the case audit trail. A copy of the email is also attached by default.
Kind regards,
Bob Lloyd
PDN/Pega Academy Forums Support Team
How in activity check case audit?
Kind regards,
Grigorij Mizonov
The standard Notify activity is an "assignment" based activity. Typically, when the assignment is created, the Notify activity is executed.
In keeping with Pega best practices, Activity rule records are small and modular. Once executed, the CorrNew activity calls the Like many activities, the Notify activity is the beginning of a string of several activities. Each activity has individual steps that are executed but here's the series of activities that are called from Notify I suggest you open the Notify activity rule record itself and read the activity. It will enlighten you.:
If you open the Notify activity itself, you will see in step 2 that it calls another activity called CorrNew.
CorrNew activity calls the standard activity CorrCreate.
CorrCreate (which is quite extensive and powerful) calls the standard process flow named VerifySendCorr displayed here for summary:
In the above flow, the CheckVerifyNeccesary Utility shape calls the standard activity named CorrVerify which determines if secondary user verification is necessary.
If no secondary user verification is necessary, CorrVerify activity escapes the flow by calling a standard activity named CorrAttach, which attaches the history note to the case audit trail.
If secondary user verification is necessary, the VerifySendCorr flow continues and after the verification assignment, the CorrAttach activity is called, which attaches the history note to the case audit trail.
Developer Help information on the Notify Activity can be found here: https://community.pega.com/sites/default/files/help_v71/procomhelpmain.htm
Developer Help information on Assignment Based Activities in general can be found here:
I personally find the best way to determine what an activity does is to open the rule and read through it and it's called activites. For instance, find the standard Notify activity rule, then use the Actions menu and choose Preview. The following two images show those steps.
When an activity calls another rule record, that rule instance is shown as a hyperlink (such as CorrNew above). Repeating the investigation helps the architect to fully understand the string of activities and other related rules being invoked.
Another method would be to trace the acvity in question (use Tracer) and when you execute the activity you can see a log of all the procedural rules invoked. More information about Tracer can be found here: https://community.pega.com/sites/default/files/help_v718/procomhelpmain.htm
Hope this helps,
Bob Lloyd
Thank you for your detailed answer.
Kind regards,
Grigorij Mizonov
