Stratosphere Technical Consulting
Last activity: 13 Jul 2016 15:53 EDT
quiz question on Draft Mode in Guardrails for Case Mgmt Design
The below question is asking which statement is false. The correct answer is 3. #2 is clearly true and not the correct answer. However is #1 a true statement.? I have issue with the word "All" . If you have draft mode on, is it not possible to still get error? Also, with #4, while I understand you would not want to send an application to QA in draft mode, would you not ever unit test your application while still having draft mode on ? Again, in this question I have issue with the word "never".
To clarify my question, especially because of the definitive words "All" and "Never" in 1 and 4, I wanted to confirm they are correct and true statements.
The following quiz question and answer choices are listed below:
NOTE: Due to cutting and pasting the check mark is in the wrong place. The quiz marked #3 as being the correct answer.
