Pega Platform 8.3 on Docker
We join two nodes to a single backend database instance, and both nodes show as Normal under
[ Dev Studio ] -> [ Configure ] -> [ Decisioning ] -> [ Infrastructure ] -> [ Services ] -> [ Stream ]
However in Admin Studio under [ View system & nodes ] only one node shows up in the list.
If we login to the 2nd node pega portal its Admin Studio node list only shows itself.
I loosely followed the steps outlined in this article
https://community.pega.com/support/support-articles/pega0090-streamserviceexception-cannot-add-new-node
1) Shutdown both pega docker instances
2) Deleted the pega image on disk
I did this to ensure the default pega tmp dir is absolutely back to its inital state
"/usr/local/tomcat/work/Catalina/localhost/prweb"
3) Use pgadmin and connect to pega db
4) Truncated all the tables
pr_sys_statusnodes
pr_sys_statusdetails
pr_data_stream_nodes
pr_data_stream_node_updates
pr_data_stream_sessions
5) Change hostname for both nodes in docker-compose.yml
6) Bring up each container watching logs for errors
- Logging into each node only shows itself under the list of nodes in Admin Studio
- Both nodes show up in Stream nodes as Normal
Partial log is attached
***Edited by Moderator Marissa to add the Developer Knowledge Share tag***
