Accenture
Last activity: 13 Jun 2016 0:40 EDT
Pega 7 CUIS- Certified UI Specialist
Did anyone cleared CUIS certification? If so can you share your experience/tips/ideas to clear CUIS certification.
Going thorough UI Specialist (7.1) course is enough or need to go thorough some other materials. Please share your views.
Thanks.
Praveen
You should be able to pass the CUIS certification using the information you receive from the UI Specialist (7.1) course. You can download the Exam BluePrint from PearsonVUE - http://vue.com/pegasystems/cuis_exam_blueprint.pdf. This will break down the exam, types of questions and distribution of topics.
Hope this helps,
Sean
Pega Academy Support Team
Sandhya Vullamparthi
Atos
Hi HEDES,
are you sure that UI specialist self study material is sufficient to pass this certification. Do you have any otrher material for the same to go through purpose.
please suggest.
Thanks in advance
Regards
Dipak
I am sure the self study material is sufficient to pass this certification. If you would like to look at additional User Interface related material you could research using the PDN landing page - https://pdn.pega.com/user-interface. However the exam is generated from the course material.
Hope this helps,
Sean
You should complete all the lessons including all exercises that are part of the course. Since this exam certifies the student as a UI specialist, it has lot of questions specifically around how to do things for specific requirements. If the student has completed all lessons including exercises then they should be able to pass.
Accenture
Ok. Thanks for the replies.
RAMAK,
Have you attempted exam? If so are there any more suggestions. Thanks.
Northbridge Insurance
Hi Praveen,
Complete all lessons and excercises, now PDN gives comment on wrong options understand them well you will be able to clear it
Accenture
I dont see Installation guide for Pega UI PVS Certification exercise. Where can we find the guide? Thanks.
Accenture
Unable to download "Exercise System Quick Start Guide", getting error 'This webpage is not available'.
Accenture
Finally iam able to download and install it correctly. No action required.
CAPGEMINI
I am unable to login using the credentials given in the exercise. Are there any other credentials for PEGA 7.1.9 version?
The credentials are
| Developer1@org1 | rules |
I have tested and verified. Please make sure you are running the correct image from the course.
Centene Corporation
Can anyone explain how the above button can be created in Pega 7.x. I know it can be created using skin rule But which attributes to be updated to form the above button?
Ai4Process
You could use a binary file or Image Content and reference it from the form and add event/action
https://docs-previous.pega.com/adding-file-image-library
Damien
Centene Corporation
Thanks for your reply Damein.
Actually there is no image as such. The above colored button is created in Pega using skins. So my question is - which attribute changes made that button look like. Thanks!
-Kishore K
Bernving Associated
Then you have to create an image. As far as I know you need to add the image to your system before you can show it. Maybe there are other ways to create this but then in a combinbation of texts and images (like the chopping kart). Anyhow that questions goes beyond our courses and should better be asked at product forums, not Academy.
Hans
Ai4Process
On your skin you can create a new "button" component (open your skin, component tab, change component to button, clone a button)
Inside the background part of you format choose "image" and you can reference your image.
This is harder to configure but it will be part of your skin.
Damien
Centene Corporation
Thanks for your replies!!
Basically this is a CUIS question. The question goes like this:
- Check all that apply for creation of the below button in the skin rule
i) Use mixins to color the button
ii) Use image include to include the cart image beside the Text "BUY NOW"
iii) Include text "BUY NOW" in the skin rule using mixins
iv) Format the borders using skin rule
v) Format the text to make it upper case using skin rule
Virtusa Consulting Services Pvt Limited
With respect to the question you had asked. The answer is second option. If you had the lessons over there , they would have explained about including the images besides the button image. As soon as you select image source for the button control as simple image of property, upon selecting the image you want a field called 'Image position' will appear next to the Image source field which has left and right options for the image to be displayed besides the button label. Hope this will satisfy this question.
You were asking about the attributes right. For the organge color of the button it is as simple like clone the strong format of the button control which is present in the skin to some other name like CustomizedStrong. To have your button label in capitalized you have the first category Text( either you create a customized mix of typograph with capitalized text or select specify styles in which select Transform Text as 'Upper case' and you can refer this format in your section where you drag a button control. Then follow the steps to refer the image besides the button caption( which you specify in the cell properties of the button control in a section)
