Covance
Last activity: 11 Jun 2017 12:00 EDT
pages and classes tab
What is the use of pages and classes tab of any rule?
When it comes into the picture? Run time or Complie time?
In PRPC What are the concepts executing things in run time and complie time? such as in java run time polymorphism
Thanks in advance
NIIT Technologies Limited
Pages and classes can be used in a rule to access other classes that are not visible/available in the rule's primary class inheritance or hierarchy.
It can also be used to define the classes of various pages used in the rule.
It comes into the picture when you save a rule.
Wells Fargo
To my knowledge Page and Classes declaration is required only during compile time.
Chiranjeevi
Services Australia
Pages defined in the Pages And Classes tab are used at design time only.
Vamshi
Covance
Thank you very much for replying....
Covance
I got the PRPC 7.1.7 help documents and it says that "pages & classes" uses at run time and many more information.
https://community.pega.com/sites/default/files/help_v717/procomhelpmain.htm
Evoke Technologies
Thank You.
As per my understanding, entires in pages and classes are used only at save time.
At run time, developer has to make sure that a particular clipboard page exists.
Someone from Pega please clarify.
Accenture
Hi Friends,
*********There was a problem saving an instance of class : Error Code: SQL State: Message**********
Have u came across the above error. When we are saving an data to External table in Obj-Save we are getting the error.
If you have faced the same kind of issue, can you please let us know the solution.
Ashiq
