Last activity: 2 Nov 2016 11:06 EDT
NOTICE: Mobile Build Server Requires Secure Connection
The Mobile Build Server operates via SSL and any Pega 7 server connectinng to needs to have the GoDaddy Root Certificate Authority installed on its system.
Follow the information below to understand how to install the GoDaddy Certificate Authority on your Pega 7 server.
This issue will come up with attempting to build a custom mobile application for iOS or Android. You may notice the following entries in your Pega 7 log files.
2016-10-25 17:14:14,758 [.PegaWorkManager : 1] [ STANDARD] [ ] [ SSL:01.01.01] (.ssl.CompositeX509TrustManager) DEBUG Admin@GCS - certificate not trusted by TrustManager: com.ibm.jsse2.yc@6b3a0fe7
- com.ibm.jsse2.util.h: PKIX path building failed: java.security.cert.CertPathBuilderException: PKIXCertPathBuilderImpl could not build a valid CertPath.; internal cause is:
java.security.cert.CertPathValidatorException: The certificate issued by CN=Go Daddy Root Certificate Authority - G2, O="GoDaddy.com, Inc.", L=Scottsdale, ST=Arizona, C=US is not trusted; internal cause is:
java.security.cert.CertPathValidatorException: Certificate chaining error
or
2016-08-24 12:22:22,858 [ PegaRULES-Batch-1] [ STANDARD] [ BeCounted:01.01.01] (nvoke.Rule_Connect_REST.Action) ERROR lakem - com.pega.pegarules.pub.services.ConnectorException: Caught unhandled exception: javax.net.ssl.SSLPeerUnverifiedException: peer not authenticated
The default path to the trust store on your Pega 7 server will most likely be located here:
In order to check if cacerts contains required entry execute the following. This command will list all entries, so you should search/grep for Go Daddy Root Certificate Authority - G2.
If you want to use truststore different than java one see (especially parts related to truststoreFile), see also:
- Tomcat (truststoreFile): Apache Tomcat 8 Configuration Reference (8.0.37) - The HTTP Connector
- JBoss: https://developer.jboss.org/thread/160371
- Web Logic: https://docs.oracle.com/cd/E23943_01/web.1111/e13707/identity_trust.htm#SECMG382
- WebSphere (How to specify the keystores and truststores): IBM WebSphere Developer Technical Journal: Using the Java Secure Socket Extension in WebSphere Application Server
***Thank you to Wieslaw Bondyra for this information***
