Last activity: 14 Oct 2019 8:11 EDT
Not able to download VM
The course is not the one selected in the drop down (System Architect Essentials (7.2)), but the one present at https://academy.pega.com/library/83/system-architect-essentials-exercise-update (System Architect Essentials Exercise Update (8.3))
After clicking "DOWNLOAD EXERCISE SYSTEM" and right clik/saving on the token link, Chrome/Firefox would try to save a "fail.html" (or "style=_font-size_.html") file and IE a "fail?[<other_characters>]?fail" file.
Is the exercise system available for this class, or should I just try the cloud environment instead?
Let me look into this.
eddie
OK, this is resolved. you can download the OVA file now.
eddie
Thank you, Eddie, confirmed, it's fixed.
Lao
The OVA (c1566.ova) received by the link doesn't seem to work.
- the appliance is correctly imported by VirtualBox
- trying to access the URL advertised by the motd (using bridged adapter) keeps the browser window busy, but with no content returned (even way after the 2-3 minutes specified)
- similar result when trying to switch from bridged to "host only" or NAT (with port forwarding) adapters
- only postgres user/password published in the description work, but not root and/or teuser
Network for the bridged setup seems to be ok, as a ssh (as postgres) succeeds on the guest.
Are there any other options needed for the VM in order to make it work?
The application comes up but in almost 8-10 times more time that the login message says. The VM login specified on the Academy application page inside the VM works.
Please disregard this request.
Booz Allen Hamilton
Hi
I receive the same error for Senior System Architect Exercise Updates 8.3. Please help me to download the file.
Thank you
That VM seems to be missing. I have an open ticket to resolve this. I will update you when this is issue is resolved.
eddie
Ford España SL
ES
I have the same problem trying to download the ova file. I attach a screenshot.
