Modifying the default tab order
Here is a situation that you might find useful while designing the User Interface.
Scenario: I have designed a UI form with input fields but would like to change the default tab order on the input fields so that a user can enter data to the fields grouped together before moving on to the other input fields.
Solution: To modify the default tab order on input fields, you can use a section to group a set of input fields and embed it within a layout or another section in the form.
Please see the following article on PDN for detailed instructions:
https://pdn.pega.com/overriding-default-tab-order-input-fields-forms
