Login problems into the PRDC Designer Studio
I have downloaded and installed the necessary VMWare, now I try to login into the PRDC Designer Studio. I have tried the 'prpc:8080', the 'prpc.:8080' and the '<ipadres>:8080'. All I get is the 'page does not exist' message. What is it that I do wrong. I use windows10 with the edge browser. Thanks.
FYI: There are a number of similar posts. Also, Pega Academy has switched to VirtualBox. You may want to do download again plus review the latest "Get Started" guide.
That said, "prpc" will not work unless you alias your IP address in C:\Windows\System32\drivers\ets\hosts
After doing that, bring up a command windows and issue: ping prpc
If that fails you need to look at how your VM's network settings are configured.
If highly unlikely that you need to access a URL outside you laptop - your best choice is "host-only adapter"
The IP address should start with 192.168.
