Vodafone Intelligent solutions
Last activity: 30 Oct 2015 6:28 EDT
How to Render JSON response from clipboard to UI ?
Hello Team,
I was trying to integrate Google Rest service which shows all the details regarding to the location, using following URL https://maps.googleapis.com/maps/api/geocode/json. I have achived the integration using Rest connector option from Integration tab and able to get the Response JSON on clipboard.
I have achived this by calling an activity on button click .
Now my requirement is to get the response on UI like Lattitude and Longitude:
This is a part of my POC and I am stucked on this part. Can anybody provide the step by step process for getting response from clipbord on UI.
Amit Goyal
Randstad Technologies US
you can use following code to create clipboard structure.then you can display them on UI using clipboard page a source for any control.
ClipboardPage stepPage=tools.getStepPage();
try
stepPage.adoptJSONObject(jsonResponse);
catch(Exception e)
throw new PRRuntimeException(e);
Hi Subba,
adoptJSONObject(jsonResponse) take argument as string so how should I pass my response which I am getting in webForm page on clipboard as JSON.
I have put this code in java method in an activity but it shows error : could not resolve jsonResponse
regards
Amit
Optus
Hi Amit,
Declare the argument as a local variable will resolve the "could not resolve jsonResponse" error.
Satish
add one local veriable in activity as jsonResponse then
before java step,add one property-set method,
then set the value to jsonResponse from your webform.response_get property.
then it will work
Hi Subba,
I have tried the things you have told me to do but the issue is still there. I am posting some screen shots for more clarity.
Please help
As you told I have created a variable jsonResponse and passed the webform.response_get.default response in it.
then I have written the code which you posted
but it is showing this error
please provide detailed solution if possible
Regards
Amit Goyal
Process 360
Please make changes as shown in screenshot below to step 4
you need to create jsonResponse as a local variable not a parameter
And you need to give step where you want to store the result of json response..then it will work.
Thanks subba and Bhanu,
The error is resolved. Now can you please tell me how to map a control on UI to the clipboard page.
regards
Amit
