How to add space or margins between layouts
I've got section with nested column and dynamic layouts
maybe this can help: https://community.pega.com/video-library/rethinking-your-uis-pega-7-using-floats
Damien
Hi
For Space between layouts may be you can get by using Float. For Borders (side Border Lines ) and Space between layouts you have to Update/add Format in the Application Skin rule and same Format need to use on for the layout.
