Help! - Stuck at Data Elements Exercise: Create Single-Value Properties
I have been going through System Architect Essentials 1 and not had too much trouble until now.
I resorted to checking the solution and I seem to have done everything the same. Now on point 6 of the solution, when I click "RUN" to test and select "No thanks, maybe later" - I do not get the option to test what I have created. I clicked information and can see the fields there for testing but they are only text - it does not look like the solution... can anyone assist?
Also - what is the best way to insert screenshots? I did not want to use imgur in case I upload something confidential...
