Nous Infosystems
error when opening “Configure Stage Behaviors” and “Configure Step Behaviors” in Chrome
Hello
Taking the SAE 1 course. Getting an error when opening “Configure Stage Behaviors” and “Configure Step Behaviors” both on the VM and the exercise system linked to the course
“Configure Step Behaviors” error similar to above
| Status | fail |
| Message |
Failed to find a 'RULE-OBJ-FLOWACTION' with the name 'PZEDITPROCESSDETAILS' that applies to 'Rule-Obj-Class'. There were 1 rules with this name in the rulebase, but none matched this request. The 1 rules named 'PZEDITPROCESSDETAILS' defined in the rulebase are: 1 unrelated to applies-to class 'Rule-Obj-Class', for example: 'Embed-StageProcess'. |
| Operator ID | LeadArchitect |
| Requestor ID | HAA8DA872051D80FD5B31E375D5435A4C |
Found a work around by using IE on my windows 8.1 laptop.
But why isnt chrome working?
Dilip,
I doubt the browser had anything to do with it. It was probably logging out and logging back in that fixed it. If you prefer working with Chrome you should be able to go ahead and use it.
Sincerely,
Cecil Howell, CSA | Senior Instructor | Pegasystems Inc.
Nous Infosystems
Unfortunatly no. tried loggin out and loggin back in on chrome
same errors
Dilip
Dilip,
May I ask, what version of Chrome are you using?
Bob Lloyd
Pega Academy Self-study Support Team
Nous Infosystems
Version 41.0.2272.89 m
Dilip
That is definitely compatible version of Chrome.
I'm going to try and escalate this a bit to see if we can't get an answer for you soon.
Thank you for your patience,
Bob Lloyd
Nous Infosystems
thank you Bob
Dilip,
Did you shut down all Chrome windows before trying to log back in? It may even be a good idea to clear Chrome's history and Cache. The error you are getting is happening on the server so it is not technically a browser compatibillity issue, I think the server is trying to retrieve something it had cached specifically for your session which is why IE worked. Wipping Chrome's cache should resolve the issue.
Cecil
Nous Infosystems
I have tried loggin out and loggin, closing the window etc.. i opened on incognito mode which i assume eliminates the cache issue
Dilip
HCL
Dilip,
Did you got any workaround for this as even I am facing the same problem.
Onkar
Tata Consultency Services
Hi Dilip
Have you got any solution for the problem? is so please let me know i am also facing the same issue.
Ram
Konylabs
I too got the same problem on chrome. my chrome version is 49.0.2623.108 m
pleae let me know,if you have any fix for this issue
Infosys
Even I am receiving the same error. Was this issue resolved ? Do we have any work around for this issue ?
I am receiving same error on chrome, Tryed many thing like updating current version of chrome but it did not work while it is working perfect with IE11.
Ai4Process
I have never seen (or at least can't recall) this error.
Keep in mind Pega 7.1.6 is not 100% compatible with Chrome or FireFox and only IE 9/10 are the fully compatible browser and they will be needed to complete some exercises (Decision Tree, Correspondence, ...) but if it is working with IE then it should work for Chrome ONLY for this particular case.
Clear cache, kill all Chrome processes, clear cache.
Damien
Ordina Nederland BV
I'm doing the Pega 7 Fundamentals.
Error is still there with Chrome (changing step to multi-step). MS Edge works without problems.
