Error when generating document using Rich Field
Hi!
I have a very specific problem, using the Step "Generate Document" in Life Cycle.
When I'm trying to generate a document with a text field of type Rich Text in a Word document I receive the following error in the generated document:
<< ERR_SKIP_HTML_IN_PARA>>
I use Document Type "File"
When I set it to plain text I don't get an error, but with HTML-tags, which is understandable.
Has anyone seen this problem before, and if so, have you found a solution.
Using Pega Platform 8.5.1
Brgds Jens
