EForm Creation 7.4
Below are the steps needed to add fields to the smart PDF. During this process I uploaded a smart PDF to Pega but I was unable to extract fields. I uploaded the smart PDF to a tool (online) PDF Escape and then downloaded the PDF (making no changes or using any function from PDF Escape). When I uploaded the smart PDF to Pega for the second time, I was able to read the fields in Pega.
Pega EForm Creation Example
- Upload your smart PDF form via the EForm Wizard
- Select > Designer Studio > Integrations > Tools > PDF for EForm Wizard
- Select the Class for the PDF
- The Class is Applied To your Case you created. In this example we are applying the PDF to the class OJ7XGI-Universal-Work – this is the lowest level in the Class Structure meaning any Cases built higher in the structure can inherit/reuse the PDF.
IMPORTANT: Note the Class the configuration applies to for use later in the configuration
- Choose the PDF to import a. Name the PDF Form
- On the next screen Select the fields from the PDF you wish to populate with information from your Case.
- Map the fields to properties from you Case.
- Open the App Explorer in the left Tool Column
- Expand Data Model > Properties to view the available properties
- In the Property Name Field, place your cursor and Click the Down Arrow to
display case properties. If the Properties do not display, enter a period “.”then the property name (ex: the LastName property == .LastName)
Note: If after creating the form the fields are not mapped properly you can return to this screen and adjust the mapped properties
- Accept the default information and make note of the Rule-File-eForm Form Name and Class for use when configuring the PDF execution step.
- In the Case Explorer Select you Case to configure the Life Cycle
- Open the Process
- Add a Utility Shape
- Open the Utility Shape
a. Enter a Name for your Rule (ex: JimsEFormCreation)
b. Select the Configuration Icon to the right of the Rule name
- See an Activity is ready for configuration
- In this Activity, we will work with the Page & Classes, Parameters, and Steps tabs
- Select > Pages & Classes tab
- Enter the Page Names as displayed below
- For the Page Names EFormPage and PDF2 the Class == Code-Pega-eForm
- For the pyWorkPage page name the Class == the same class level you identified for the PDF you mapped above
- Select > Parameters tab
- Select > Steps tab
- Expand Step 2 -- Property-Set
- Enter the PropertiesName and PropertiesValue as defined below
- Enter the Parameters as defined below
- Save your work
- Enter the 7 steps as Displayed below
- Step 3 == “Call GetEFormFromRuleFileEForm” without the parenthesis
- Expand Step 3 -- Call GetEFormFromRuleFileEForm
- ClassName == ...Enter the Class the PDF is applied to
- FileName == ...the PDF name you defined above
- FileType == PDF
- Expand Step 4 -- Call GenerateEForm
- Expand Step 5 -- Property Step
- MapPurpose == ...the PDF FileName identified Step 3
- TargetEFormPage == PDF2 (the page name identified in the Pages & Classes tab
- Enter the PropertiesName and PropertiesValue as defined above
- Expand Step 6 -- Call AttachEForm
- 23. Method Parameters
- Save your Work
25. Close the Edit Activity Tab 26. Save the Process
27. Save the Case Life Cycle
28. Test the EForm Configuration
- PageName == pyWorkPage (defined in the Pages & Classes tab)
- InsHandle == .pzInsKey (this defines the Case ID)
- FileName == ...the PDF FileName identified Step 3
- eFormPage == PDF2 (defined in the Pages & Classes tab)
- pyNote == enter a short description to be Displayed as the Attachment Name, for Auditing purposes, and to become part of the attachment metadata
