Wipro Technologies
Last activity: 13 Aug 2015 2:06 EDT
EDIT Button for Clipboard Page
I removed clipboardViewerUpdate privilege from my Access Role , Still Edit button on the clipboard is not disabled. We need to show clipboard in read only mode to user.
Kindly suggest
Wipro Technologies
Please suggest
could you also please check: Privilege to access ClipboardViewer rule...
NIIT Technologies Limited
ClipboardViewer privilege is used to disable complete clipboard.
Functionality needed here is - user should be able to open the clipboard but he should not be able to edit the values in clipboard pages.
Looks like, section used is not configured to disable 'Edit' button when user doesn't have ClipboardViewerUpdate privilege.
is this the rule we're talking about?
RULE-HTML-SECTION PEGA-CLIPBOARD PZCLIPBOARDRIGHT #20150106T090736.057 GMT (copied pzInskey from ML 8)
when conditions are not met, the button will get hide is the configuration on the section rule... could you please specify PRPC version...
PRPC Version: 71 ML7
Section name: Pega-Clipboard.pzClipboardToolbarWrapper
When rule configured for disabling button: Pega-Clipboard.pzDisableEdit
I think there should be a condition for privilege check inside this when rule.
Thank you...
- are we reading the rule from Pega-Desktop:07-10-13 ruleset version in ML 7?
 - I see there is an update on this rule in ML8 validating the privilege ... in Pega-Desktop:07-10-17
 - you may need to contact Pega Global Support team.
Yes, the same rule.
Thank you.
