Cases/work objects processing behavior and configuration in theme cosmos applications
In theme cosmos applications, case assignments are processed in ajax containers (OOTB platform feature). There are three ajax containers used and customized for cosmos specific behaviors. Below are the ajax containers and their usage:
1. ACPrimary – for processing the case assignments
2. ACSecondary – for showing the preview panel
3. ACTertiary – for showing the create modal and other work actions on dialog containers
By default, when a case is opened, the assignments are processed in primary ajax container.
For case’s flow actions and local actions, these are also processed in ajax containers and are launched in tertiary ajax containers
Configuration:
OOTB harness actions api from the platform has been enhanced to support theme cosmos behaviour. We have exposed a new parameter to process the case assignment in a ajax container.
Updated ootb action api’s:
- pega.ui.HarnessActions.handleMenuAction
- pega.ui.HarnessActions.addWorkFromActionsMenu
Targeting ajax containers:
Action Api |
Parameter to target primary ajax container |
Parameter to target tertiary ajax container |
mdcTarget : acprimary |
mdcTarget : actertiary |
Note: By default, when flow and local actions are launched from preview panel, the assignments are processed in tertiary ajax containers.
