Accenture
Last activity: 6 Nov 2015 8:51 EST
Can we run a SafeURL into the dynamic container?
I m working on PEGA 7, This question is regarding composite portal,
From the left panel of composite portal, I am running a SafeURL , through which a activity is getting called which loads a harness.
The problem is that the harness is diplayed on the entire screen intead of the dynamic container present in the work area.
Is there a way to display the harness in the work area (dynamic container) using SafeURL?
