Wellsfargo
Business days difference in Report definition rule
Is there any functions available to calculate business days difference in report definition ?? if not please suggest how to calculate in report definition ??
Without knowing your exact use case / user story, expected report results, and which version of Pega (PRPC) are you using (example: PRPC v6.2sp2, Pega 7.1.6, etc.), it is difficult to provide a specific answer.
In a Report Definition report, you can populate a column of the report using an nested SQL function and Standard functions available in the Pega-RULES:BusinessCalendar library are available which use business day and holiday information.
Something to keep in mind here would be the Pega definition of 'Business Days.' According to Pega Developer Help:
A business day is a day that is not identified as a holiday nor identified as a weekday with no work, on the Schedule tab of a calendar data instance.
Standard functions in the Pega-RULES:BusinessCalendar library use business day and holiday information. For example, you can compute the number of business days (based on a specific calendar) between two dates. Business days are sometimes called work days.
If your application includes multiple calendar data instances, a non-business day for some users may be a business day for others.
That being said, consider using a BusinessCalendar function in one of the data columns. Here is a link to a PDN article you might find helpful: https://pdn.pega.com/reporting/how-to-use-nested-sql-functions-in-report-definition-rules.
Kind regards,
Bob Lloyd
PDN and Pega Academy Self-study Forums Support Team
