Bug: Manager Portal Cannot Save Report
Discovered a slight bug with the default Manager portal created by Express wizard (Pega 7.1.9 on premise) . To recreate:
- Switch Portal to "Case Manager 7"
- On the left-hand navigation, click "Reports"
- On the right-hand navigation select "Add Report"
- On the "Create New Report" popup choose a case type and report type
- I was then presented an error that read "You must have a local ruleset available to create a category/report"
I suppose there is a workaround to this by navigating in Designer Studio and adding a production ruleset. But since the 'Add Report' feature appears, it should work properly.
Thanks!
Phil
Thanks for reporting this. We have fixed this in the upcoming release.
