addDays function returning different values
We are using addDays function to add a specified number of days to a Date. This function is used within an Activity and this Activity is called from two different applications. In most of the cases, the resulting date will be same in both the applications. However, in very few cases, the dates are different - one day less in the second application. The Primary page used is different in each application. Upon tracing, I found that the date difference is after the addDays function is executed I mean there is no other formatting or logic that is used down the line to update these dates. We are using the @addDays(String,int,boolean,String) format of this function. Any insights on why this could be happening and only in some cases?
