Landing Page in Constellation do not show a form view option with submit action button
Use case: Display a registration form(landing page) to user to fill data and submit
Desired Solution: After submit of the form, system needs to create case in backend to further process the approval of the registration request. Following data instance first approach
Problem Statement: In Constellation UI, we are able to create a view in landing page with only 'Table format' not a form. Hence, forced to move to a solution to provide a direct case creation approach leading to lot of unwanted cases being created in system. Kindly suggest, if above use case in Constellation architecture possible with data instance first case design approach ?
Product version: Pega Infinity v24.1
UI Architecture: Constellation
