CI
Last activity: 12 Jun 2024 1:08 EDT
How to change button style .
Hi Guys,
I used one ModalTemplate section in base calss in section submit button come like different.
Please check once in screen shot .Please help me how to remove that double line .
Reply
Updated: 12 Jun 2024 1:08 EDT
@kirti - Then some custom styles might be getting applied. Try below change in UserWorkForm and verify the issue.
<style>
.Simple.buttonMainTable{
padding-bottom: 0px !important;
</style>
Thank you.
Capgemini Technology Services India Limited
Click on button configuration in the section where it is placed and navigate to presentation tab and change the control format to Standard.
CI
Also you can put value for button style param as Standard ,Strong, Simple or Other. Hope it resolved your issue.
Updated: 11 Jun 2024 9:26 EDT
Eclantiqx
@kirti Try to change the style of button . It should be different CSS style also in presentation layer of the same button control try to change the CSS setting. In case both not works . Open any Pega OOTB submit button control and copy exact each step . You will get correct output. Things wil defintely work take the correct input from already created buttons.
Eclantiqx
Hi @kirti
I have used the same pzModalButtonSubmit in my use case but I am getting result properly so please refresh or try creating it again.
please find the below screenshots for reference
CI
As per requirement button style I need to put Simple only with orange color and orange board.
But when I click on search button pop up window open. That time submit button come like that click on popup window.
can you tell the name of the section that you used for modal template
CI
@kirti -
1. Open application skin
2. Select buttons -> Simple
3. Verify the preview in this rule
If the skin has inherited skin verify the above in other skin rules as well.
If its properly seen then some styles from some css file is impacting.
Thank you.
CI
Button style I checked in Skin level also. everything is fine on skin but in Ui button come like that.
<style>
</style>
Thank you.
