Email Account-Microsoft Graph- Email Display Name
Email Account with Microsoft Graph API, as pyFromFullName is not there - is there a way to capture the display name (while sending the email) ?
Example: Display Name <Email ID>
Thank you...
***Edited by Moderator: Pooja Gadige to move from Pega Academy to Product, add product details tag, add capability tags***
@DharaniM5625 @dkantala
To capture the display name while sending an email using Microsoft Graph API, you can configure the 'pyGetDisplayNameForEmailAddress' data transform rule for the 'Work-Channel-Triage' class. You can edit this data transform rule to display the user name in the desired format.
Configuring the email bot to display a user name in emails
