Anthem
Last activity: 4 Dec 2023 8:57 EST
Issue with pickup correct rule
HI All ,
I am facing the below issue with rule resolution can you help me with this.
I have saved pyCaseActionArea section rule in our application class ABC-FW-DMCFW-, When user1 logged into the application pyCaseActionArea rule is picked up from the ABC-FW-DMCFW- class as expected.
Whereas when user 2 is logged pyCaseActionArea rule is picked up from the Work- class.
What could be the root cause for this issue?
@shyamshankar Did you check if the ruleset stack is the same for both the users? You can do a remote trace for user2 and see if the rule is getting picked up from cache
