GFT
BR
Last activity: 13 Oct 2023 21:32 EDT
Only Numbers in a text box
Hi, I am looking for a way to restrict a text box in a form in order to take only numbers and thus impede the user to put letters, specials caracters etc. I have seen few posts here but none of them seem to have worked for me.
here are some similar topics that I came across during the research on pega support area.
Number Format | Support Center (pega.com)
Validation to only allow numbers in a text box? | Support Center (pega.com)
On property field, in the "Advanced tab", the 'Use Validate' there are some options and the most relevant one was the method "IsInteger", but it is a big number with 11 characters and it won't take as it turn up an erro message saying it is not a valid integer.
Can someone please help with this?
I beforehand appreaciate your help.
Hi @ThiagoC16880758
We have to write our own java message or edit the field value for that, for the editing the field value is not best practice, any way you can try by using the saveas field value,
Rule Type: Field Value
Rule Name: pyMessageLabel • numeric_decimalMsgStr
Ashok
