Aaseya IT Services Pvt. Ltd.
Last activity: 3 Apr 2024 7:13 EDT
Search and Select Pattern - Constellation UI
I am implementing Search and Select pattern in Constellation UI (8.8.3). As per the below link, I have created a field with Data reference and kept it as a single record in case level. In case view, I have added the field. When I configure the view inside the field, I am not able to see the Search Data page (Which is shown in screenshot). Can anyone let me know if there are any additional configuration required for Search.
Thank you.
@Krishnakumar Sivaradjy
I had similar issues in the Pega 8.8 version. However, this issue seems to be fixed/enhanced in the Infinity 23 version and worked fine. Check on later versions, and let me know if you're running into the same issue.
