Searching archived cases
Hi everyone Do you know if you can obtain properties that you manually created and optimized using pxRetrieveSearchData? Our client is trying to search archived cases with properties they created. They only can serch with caseID's They are referring to the below document. https://docs-previous.pega.com/system-administration/87/reviewing-archived-case-data Thanks, Kana
