NA
Last activity: 5 Apr 2023 13:01 EDT
How to display asterisk beside label for required properties when they are in readonly mode in 8.7.4 Version
It seems that there may be a slight issue with the display of mandatory fields in your UI. When these fields are in editable mode, they are accompanied by a label and an asterisk, but in read-only mode, the asterisk is not present. However, it would be helpful if the asterisk could be displayed for mandatory fields in read-only mode as well
@CHAVSATYANARAYANA
By including the below styling code beside field label value would display the asterisk.
<span><font color='#D5AB55'>*</font></span>
