Wipro Technologies
Last activity: 8 Feb 2024 11:37 EST
Getting error "ID":"Pega_API_055" ,"message":"Validation messages found."
hi
I tried creating a case through Pega API - I do have the property configured as a page property and there is no validation on the property
While I am trying to create a case through Pega API - I get a 401 error message - please could someone guide me?
The Body I am trying to use is :
"caseTypeID": "XXX-XXX-Work-XXX",
"processID": "pyStartCase",
"content": {
"Customer":{
"CustomerID":"1"
"ID":"Pega_API_055"
,"message":"Validation messages found." and the error message is:
hi
"content": {
"Customer":{
"CustomerID":"1"
"ID":"Pega_API_055"
"pxObjClass":"Pega-API-CaseManagement-Case"
,"createCaseRequest":{
"caseTypeID":"XXX-XXX-Work-XXX"
,"processID":"pyStartCase"
,"pxObjClass":"Pega-API-CaseManagement"
,"content":{
"pxActiveChannelFromAPI":"Web"
,"pxCreatedFromChannel":"Web"
,"pxObjClass":"XXX-XXX-Work-XXX"
,"Customer":{
"CustomerID":"1"
,"errors":[
"ID":"Pega_API_055"
,"pxObjClass":"Pega-API-Error"
,"ValidationMessages":[
"pxObjClass":"Pega-API-Error-ValidationMessage"
,"ValidationMessage":"The page contains an undefined property: pyWorkPage.Customer\nValidation failed: Errors Detected."
Please note if only Page property is given (not the embedded property within page - it works and I get a 201 created message
@JaghadishR: This is now solved - was a silly mistake but for others to note
While configuring the Service Package from which this API is run - the access group should have access to the properties defined - else this error would pop up - so careful in selecting the access group - cheers
