PayPal
Last activity: 30 Nov 2022 12:04 EST
Reading BLOB data from pzPVStream column with Java
Hi Team,
We have a requirement where we need to read the pzPVStream column(in one of our tables)
from a Java application.
As the column is currently compressed and encrypted by PEGA, do we have any detailed documentation or suggestion on how it can be done? How we can decompress and read the BLOB data from pzpvstream column.
At DB level, we can use PR_READ_FROM_STREAM but it fetch only the required particular property inside the BLOB. we want to read the entire BLOB at once for a record.
Can you please help here on this? Thanks!
Hi @ashwinkumars: I see 2 things in the query. Title says to read stream data using java. In this case if you are referring to java code within PEGA application, you can make use of the interface Database and function open to open a work object.
Sample: tools.getDatabase().open(<Page>, false)
Details says as a Java application: If you are referring to a external java application,
I don't see a option to read entire blob data from a external Java application. As mentioned earlier, index / reporting table / API is more recommended.
Thanks.
