Download a PDF from the embedded PDF viewer
Hi Pega,
For an use case I need to download a PDF file from a web application. This PDF file can be downloaded by clicking the download button in the embedded PDF viewer (see image).
When interrogating I can only interrogate the parent object. This object doesn't have any useful methods for me.
Is there a better way to dowload this PDF file? Running version 19.1.109.
@RobinT51 Depending on what PDF viewer you are using; you might be able to interrogate the control. You might try removing your current PDF viewer and instead using the stock one that comes with Chrome or Edge. If that doesn't work, let me know and I can make other suggestions.
