AXEOM NEW LLC
Last activity: 3 Feb 2016 9:25 EST
Pega Mobile and SSO
I am working on building a POC of a Mobile Application using Pega Mobile Client approach in Pega 7.1.9
My question is: Did anyone successfully implemented a Pega mobile app to use SSO for authentication using oAuth 2.0(by writing some custom native code)? or is there an alternative that pega mobile team recommend before they support this OOTB?(As per GCS, Pega Mobile with SSO is not available OOTB). Also, at this time, we don't need the offline support for the POC that i am building.
Any input is appreciated
Yes this is supported in Pega Mobile Client. We had another customer use it for an offline application.
However, you must use the Pega login screen for the mobile application. That is the key for it to work as of this time.
