Centering text in dynamically generated table
I have created a dynamically generated table within the full section editor. The table is fed with a report definition and is properly displaying all the data I need. I applied a custom table style to try edit the look of the table. I have entered the vertical-align and text-align center tags to the additional styles section. I have entered these tags into every additonal text styling sections I could find (column heading, row, default, summary etc...) within the custom table style. I have also addded the tags in the odd and even rows styles I have created. So the heading and data are not being centered. However, the last column is being centered.
Perhaps important to note is that the last column is reading the .pxUpdateDateTime property.
@AhsanK80 Correct way to design the UI, Please apply the styles in skin rule and refer the format and avoid custom style.
