Skandiabanken
Skandiabanken
SE
Skandiabanken
Posted: Jul 30, 2020
Last activity: Jun 14, 2021
Issue with Decision table return value starts with Call
In decision table ,The return value is configured as Call Center but it's causing rule not found exception. The value is being interpreted as Call method .
Failed to find instance myOrg-myApp-Data-Loans.Center of type Rule-Declare-DecisionTable. |
You can try the solution in this Support Article.
https://community.pega.com/support/support-articles/decision-table-return-value-staring-call-calls-dt
