How to make Autocomplete Address Form using Google Map API
Is it possible to use autocomplete for searching the address using google map api and address list should be limited to one country ..
Any update on this .
To avail the autocomplete for address search using google api,I extracted the JS file from developer console and tried it with non-autogenerated section rule but autocomplete is not populating with values .
https://developers.google.com/maps/documentation/javascript/examples/places-autocomplete-addressform
Then later i tried to consume an api by passing valid api key but it's throwing connection timed out from pega connect rest rule
** ** Caught unhandled exception: java.lang.RuntimeException: org.apache.http.conn.HttpHostConnectException: Connect to maps.googleapis.com:443 [maps.googleapis.com/ Proprietary information hidden] failed: Connection timed out: connect |
. if i send the same request from browser then getting valid json response
