Last activity: 1 Jun 2020 13:03 EDT
Ask the Expert - Cosmos UI with Sam
Join Sam in our first Ask the Expert session of 2020 (3rd - 14th Feb) on Cosmos UI
Meet Sam: Sam is a Senior Product Manager for Cosmos UI and UI-Kit at Pega. His extensive career background includes web and mobile software engineering and consulting, specializing in low-code application development.
Message from Sam: Hi! What I love about product management and my earlier consulting roles is interacting directly with partners and customers. Thus, I am absolutely thrilled to be part of this session and collaborate with you on Cosmos topics! To get the most out of the session, I encourage you to explore Cosmos with these two short articles on the Pega Community: “Creating a Basic Cosmos Application in Pega 8.3” and “Migrating an existing application from UI-Kit to Cosmos UI”.
Ask the Expert Rules
- Follow the Pega Support Community's Community Rules of Engagement
- This is not a Live Chat - Sam will reply to your questions over the course of the week (3rd - 14th Feb)
- Have fun!
Likes (3)
John Sullivan Benjamin Hui Tilak Cherukuri -
ScotiaBank
Where shall i post the questions?
Hi @ReshmaK3!
You can post your question right here and Sam will see it and can answer it for you! :)
John Sullivan ManojKumar Ravi
ScotiaBank
Thanks!
You're welcome! :)
ScotiaBank
Question : Does CRM Framework support Cosmos UI for Pega 8.3 or 8.4 ?
Hi!
The CRM framework currently does not support Cosmos in 8.3 or 8.4, but it will in an upcoming release.
Sam
Brendan Horan
ScotiaBank
Thanks Sam! I have one more question is Cosmos UI production ready for use in 8.3 Environment ?
Hi!
Yes, it is production ready and supported in 8.3. I encourage you to stay up to date with the patch releases.
Brendan Horan
Hi Sam,
I like the cosmos design. I assume that the cosmos design focusing more like a single web page application. So, there are no tab structure available to switch between work objects. User has to use either recently viewed items tab or browser back button to go back and forth. Is this understanding correct ?
When migrating the application to cosmos design, there are some requirements to update the cosmos theme in the application level, Is there a specific guidelines or standards you can point to follow when customizing the theme.
Is this design supported in IE11 ?
Thank you,
Regards, cherb.
Hi!
Indeed, Cosmos is built in a Single Page Application (SPA) architecture. Under the covers, we're using the platform's AJAX container, which allows you to load case data in portions of the screen. In addition to refreshing only portions of the page, this architecture allowed us to do powerful things like load case data in the "Preview panel" without losing your current context. And, this architecture significantly improves performance: the underlying JS and CSS is loaded and parsed only once (as opposed to tabbed multi doc dynamic container, which relies on underlying iframes and reloads/parses the JS every time).
Regarding working with case data in tabs: Yes, you can do that. In Cosmos, this is supported by opening case data in browser tabs (as opposed to in-app tabs using multi-doc DC). For any Link that calls "Open work", you can right click the link and select "Open in new browser tab." A new browser tab will render just your case (without the overall application navigation ribbon, which remains in the main tab).
Here's an animated gif demonstrating it:
Hi!
As you mention, you can also use the browser back and forward buttons to navigate. (There were improvements in upcoming 8.4 release for this)
Regarding customizing the theme in Cosmos and guidelines: You should create a new skin and inherit from CosmosSkin (located Theme-Cosmos ruleset). I recommend a new skin because it's much easier to start fresh rather than fix up an existing skin with many custom formats, overrides, etc. Then, use App Studio to do basic branding, such as changing application logo, application title, and mixin colors.
Cosmos is a turnkey experience for case management applications, which means it's opinionated and prescriptive. We have an entire design organization that specializes in case management, and the idea is to provide you a ready-to-use, top-notch experience and allow you faster time to market, and to make upgrades to future versions of Cosmos seamless (as opposed to UI-Kit, where you Save-as rules and have to reconcile changes to those rules for every UI-Kit upgrade) Thus, stick as closely as possible to the Cosmos look and feel and functionality.
- Avoid overriding skin formats specified in Cosmos.
- Don't change the Theme-Cosmos sections to point to other design templates. For example, CaseHeader (the header in a case) is based on a design template called "Case header UI template". Don't point it somewhere else. This will break away from the Cosmos design system and it will break you when you upgrade to future versions of Cosmos. Use Cosmos as-is, mapping your data into the regions we provide, and upgrades should be seamless.
- Generally, stick to the guidelines at https://design.pega.com/
- Convert existing section rules to use OOTB design templates (or, when you find repeatable UI patterns in your app, create your own design template, following Cosmos design system)
- Other guidance is provided in the migration guide: https://collaborate.pega.com/discussion/migrating-existing-simple-applications-ui-kit-theme-cosmos-section-based-ui
Our stance on IE11 is basically "graceful degradation"; The application should work, but modern browsers will provide a richer experience.
Sam
Tilak Cherukuri Brendan Horan Venkateswara Reddy Yerasu Sumit Koolurker
Thank you sam for detailed answer.
Wipro Ltd.
Question: would there be any tutorials on how to use Pega Cosmos Libraries in Sketch? just a quick demo highlighting main layouts/components and how to edit them would be enough...
Let me introduce you to the Pega Design team, who can better answer that. Stay tuned...
Brendan Horan Jason Pok
Greetings. Take a look on Design.Pega.com for a basic overview.
Also, would love feedback on which of your questions were (or were not) answered.
Brendan Horan
Wipro Ltd.
Thanks. I was thinking more in the terms of creating a basic wireframe. How to set up the main layout and play around with different components and actions through Sketch
My issue was after I set up Cosmos on Sketch I wasn't sure what to choose to start with the layout... I noticed in the Pega Design Studio there are several layout templates however in Sketch Libraries I could only find 3 or 4 examples of pre-populated screens
We are currently compiling the most common page templates for people to use in their app builds, as well as rules around when to design with what. I am interested, what are you trying to design specifically, so I can take it back to the team?
Actual uses cases help us make a more complete out-of-the-box package for you.
Brendan Horan
Tata Consultancy Services
Hi Sam,
The below are my assumptions from the various conversation I have had:
1.) Sections should be made on design templates to make it make them React Components
2.) Each section will be a React Component
My questions:
1.) If we build custom design templates, do we have to write our own React component generation code for the template. If yes, how complex / easy will it be to write for someone who already knows React?
2.) Will the actions like Run Activity, Refresh Section work in Cosmos UI? Is there any specific list of actions that will / will not work?
3.) Is there plan to support Grid Repeat, Repeating Dynamic layout, Layout groups in Design templates.
Thanks.
Also one suggestion:
Generally screens gets complex creating sections inside section or layouts inside layouts when we have to display questionnaire.
The main reason for creating section inside section being that the client side required condition check cannot be applied to inner section whereas the visibility condition translates to inner section. If Pega provides a way to couple visibility condition with Required Condition it will solve most of the issues and unnecessary complications. I am talking about a feature like the required condition will be checked only if the field is visible.
1) Correct, section rules should be based on design templates. For our OOTB design templates (1 column, "List item" templates, and others), the React component will already exist. For any custom design templates, a front-end developer will need to write a React component. For a developer knowledgeable in React, this should be straightforward. We have a strong front-end organization of React developers who will provide more guidance as we build out this architecture, so stay tuned.
2) Assuming you mean Cosmos UI that runs on our exiting UI architecture, yes, those work. If you're talking about the React-based UI engine, there will be further guidance as this architecture is built.
3) If I understand your question correctly, you're asking about the ability to add table (grid), RDL, and layout group directly from App Studio. Currently, developers must first create another non-templatized section that includes items, then use App Studio to do a section include to that section. There are no current plans to address that. This is a gap where you must use Designer Studio.
For your last question/comment, let me see if I can get a colleagues in the Core UI components group to respond.
Aravinth Thangavel Brendan Horan
ASB
NZ
Hi Sam
We are using Pega Government Platform on Pega 8.2.1. We are planning on upgrading to Pega 8.4 in the next few months. Do you know if Pega Government Platform is going to start using Cosmos?
Matt
Hi. Let me reach out to PGP product manager for more specifics. Stay tuned.
sam
Stratosphere Technical Consulting
Is there documentation to talk about upgrading from a non-UI-Kit application to cosmos? What is the process look like and what are the main things people should look out for?
Hi
If not using UI-Kit, then I’m assuming some of your rules are branches from rules in Pega-EndUserUI.
I believe the process and level of effort is very similar to the guidance in migration guide from UI Kit to Cosmos. (Link earlier in thread):
Un-override rules like Perform/Review harness and pyCaseMain and pyCaseMainInner section rules.
Open pyCaseMainInner (Work-) from Theme-Cosmos ruleset, save-as to a case-specific class in your ruleset. Use App Studio to customize.
During migration, change section level rules to use design templates for more consistency and and editing in App Studio.
Does this help?
Benjamin Hui Brendan Horan
Hi Sam,
Is the Cosmos application supported in mobile (Pega Mobility Client and Mobile browser) ?
Thank you,
Regards, cherb.
Cosmos in Pega 8.3 did not yet have the mobile experience.
I'm happy to announce that Cosmos in Pega 8.4 includes a mobile experience for both the Pega Mobile Client (PMC) and mobile browser. Similar to desktop, many of the mobile aspects can be customized using App Studio.
Also, you can take advantage of new PMC features, such as native lists. There's a preconfigured mobile channel with the native features enabled, so you can just click to build for iOS or Android.
Sam
Sam,
Thanks for your answer about the upgrade. I have 2 additional questions:
1. Does Cosmos work with the accessibility framework?
2. What is Pega's vision for Cosmos and UI-Kit? Are they both be supported and continue to improve in the near future? Or Cosmos will eventually replace UI-Kit?
Thanks in advance.
You should be fine with the accessibility framework. Generally, we test for accessibility while developing Cosmos. Though we strive to follow accessibility best practices, if you find something we missed, let us know.
Regarding UI-Kit and Cosmos: For a while now, we've spent considerable time evolving and improving UI-Kit, especially during my tenure. It is still supported. But we believe Cosmos is the strategic direction and that is where we're devoting our front-end resources. Cosmos will most definitely continue to improve, and it's a significant part of Project fnx, the "ongoing evolution of the underlying architecture of Pega Infinity."
UI-Kit 15 in upcoming 8.4 will only contain bug fixes reported by customers.
Sam
Updated: 11 Feb 2020 9:32 EST
Atos Information Technology GmbH
DE
does this mean in the future Cosmos will be the "happy path"? I'm trying to figure out if we should use Cosmos or UI Kit in my new project which has some back office and customer facing elements. Is there any comparison grid with pros & cons?
Hi!
Yes, the front-end organization is investing in Cosmos and the new front-end architecture portion of Project fnx. While UI-Kit is still supported, we're not actively investing in it.
While I don't currently have a comparison grid with pros & cons, generally, Cosmos is a far more superior experience than UI-Kit. Besides the new visual treatment and interaction patterns for working with case data, the improved single page architecture Cosmos offers (where only small portions of the screen are refreshed) is a basic feature for all modern web apps these days. (Case Worker portal in UI-Kit was SPA, but Cosmos uses this architecture in more ways).
Cognizant
1.Is cosmos supported for CPM framework?
2. In the Pega controls like dropdown- can we change the behavior of dropdown control- meaning when you hover over dropdown options the color can it be changed?
Hi!
1. Our internal app teams will adopt Cosmos, as it is our strategic direction, but I cannot offer dates on when a framework will offer Cosmos.
2. Cosmos is prescriptive and opinionated about not only placement of items but also styling of items. This is to help teams build apps with an OOTB great experience as quickly as possible (faster time to market), improve consistency, and reduce code maintenance (I've seen apps with inconsistent styling and skin rules with so many skin formats that developers are not sure what a format does or if anyone is using it). The CosmoSkin skin offers opinionated styling for dropdowns. It is discouraged to override the styling.
You should definitely have your own app skin that inherits from CosmosSkin, which allows you to use App Studio "Settings" to do basic branding, like changing the mixin colors, modifying the app name, and modifying the app icon. But teams should not override skin formats in the Cosmos skin.
Synechron
Hi Sam,
Do we have Toggle option in Cosmos ?
Hi!
I'm assuming you are referring to the toggle control that is very similar to typical on/off settings in the iOS settings panel.
We intentionally do not offer that OOTB. See the components styling here: https://design.pega.com/components-fields
Can you tell us more about your use case? Is this for a desktop or mobile design or both?
Hi Anirudh,
Feel free to continue this conversation by stating your use case as well as additional suppirt details as a new Question on PCC.
Thanks!
Thank you for the great discussions! We are closing this session now. Please continue asking your questions related to Cosmos UI on PCC.
Special thanks to our expert, Sam Alexander for getting our first Ask the Expert session in 2020 to an absolutely awesome level!
