How to use GITHUB as source control in Pega?
Good day!
May we ask on how to use GITHUB as source control in Pega 8.3.0 instead of default check-in/check-out mechanisms?
Please provide the steps to use GITHUB as source control.
Reason: We have a project of deploying as well the Pega code in both DB tables and GITHUB repository in case that the DB rule tables have been corrupted, then we have a backup that we can able to retrieve in GITHUB.
Thank you in advance and More Power!
Dear Felicita,
It's near to impossible to use git instead of checkin/-out rules process, because it's burned in Pega engine and one could not achieve that in a reasonable time and effort.
If you're afraid that your DB table will be corrupted (what're the reasons, btw, you foresee for that?), just do a full DB backup every week/day. In case of db corruption, you can roll everything back
