TN
RU
Last activity: 12 Aug 2019 7:29 EDT
Report Definition. The data source from clipboard.
Hello!
In the context of my task, it is necessary to take data from clipboard of case and use it for output in the report definition.
Can this be done?
For example, there is data (Figure 1). You must enter the BorderoStaff (). Carriage () values in the report definition. But I can’t. Can you advise a solution? I will be grateful for each answer.
Can you check if https://collaborate.pega.com/question/how-source-report-definition-using-clipboard-page helps.
Thanks!
