Cognizant Worldwide Limited
Last activity: 25 Jun 2019 12:17 EDT
Using When Rule
when rule is one of the most important rules we use in Pega which is used in multiple situations like using in a data transform or for skipping stages. As we know when rule is a boolean condition and we check whether the condition returns true or false. In Pega 7, we can assign true or false condition in either data transform or validate rule by defining the condition as we wish like ("True", "true" or "False", "false"). But it is not the same in when rule itself like using it to skip a process, we are obligated to use only starting with a small letter 't' or 'f' like ("true" or "false"). Using capital T or F doesn't run as we expect.
***Edited by Moderator Marissa to update Content Type from Discussion to Question***
Hi @GowthamC4893!
Are you having trouble with this while in a Pega Academy course/module?
Thanks!
