unable to start process iexplore.exe and notepad.exe
Hi there,
I am facing the following issues,
unable to start process iexplorer.exe for web application
unable to start notepad.exe for windows application, notepad. This is same for all the windows applications.
i have attached a screen shot, i am getting similar pop up for windows applications
As suggested in old posts, I have changed the settings,
Tools->options->studio diagnostics->output publisher -> off
It is not working.
I am using
Window 10 enterprise
OpenSpanStudioSetup_8_0_1016. this version was working fine with windows7
I have installed Robotic studio as Admin
IE version:11
Please help.
There can be different reasons for your issues. Try the following:
1. Try higher version. 8.0.1093 or even 8.1.x. Install as admin.
2. Try to launch Pega Robotic Studio as admin.
3. Check the latest Windows updates. There were some comments about problematic one.
4. Check that you have correct parameters for Notepad:
5. Check that you have correct parameters for IE:
